Since this is a Honeybee question, it's better to post your question directly on the Ladybug forums: https://discourse.ladybug.tools/
Post a screenshot of your script, and if possible, a grasshopper script (with geometries internalized) of your problem.
There could be a lot of problems here: are you using the run EP or run OpenStudio component? Which version of OpenStudio are you using?
S
