You seem to only be concerned about these three points, and you're using daylight sensors to define them. The problem is the Radiance measure only takes the input from the primary daylight sensor for each zone as input. A secondary problem is that DView doesn't really work well with about half the output data from the Radiance measure. Ideally, you'd use the illuminance map to define a uniform array of points of interest, which you can look at with results viewer (or look at the csv file with whatever visualization tool you wish).
