For ZoneTerminalUnitList since it is extensible, you should be able to use as many fields as you want presuming that you are modifying the IDF or epJSON file using a text editor. If you are using IDF Editor, go ahead and make the changes to the IDD file so that more fields show up. You can also create customized reference lists directly in the IDD file and the IDF Editor will use those. EnergyPlus itself doesn't care if you add \reference or \object-list to the IDD file.
