I managed to figure this out eventually. For anyone else having the same issue, I made a few changes but I think what ultimately fixed it was: - Re-ordering the components in the Thermal Zones tab so that the Radiant elements were first in the list. - Adjusting the internal source constructions to make sure the radiant loops were between the right layers. - If using the constant flow radiant, changing the temperature schedules to be controlled by Outdoor Air Temp instead of the zone air temp.
