The curve that you are referencing in "Electric Input to Cooling Output Ratio Function of Temperature Curve Name" should be equal to 1 at the reference conditions set by "Reference Leaving Chilled Water Temperature" and "Reference Entering Condenser Fluid Temperature"
To learn more, please read the InputOutputReference for the Chiller:Electric:EIR object.
