@__grant_payne__ if you are starting the simulation with the EnergyPlus CLI, you can pass in a custom idd path using the flag below.
-i, --idd ARG Input data dictionary path (default: Energy+.idd in executable directory)
You may also be able to copy the idd into the same directory as the IDF fie you are running, but try --idd path first.
@__grant_payne__ if you are starting the simulation with the EnergyPlus CLI, you can pass in a custom idd path using the flag argument below.
