Currently the shading surface in OpenStudio doesn't have a field to store the base surface.
The overhang user script and measure do name the surface after the subsurface object it is made above. You can use an Energy Plus measure add the additional data.
The overhang user script and measure do name the surface after the subsurface object it is made above. I over. You can use an Energy Plus measure add the additional data.additional.
The overhang user script and measure do name the surface after the subsurface object it is made I over. You can use an Energy Plus measure add the additional.
Currently the shading surface in OpenStudio doesn't does have a field to store the base surface.
The overhang user script and measure do name the surface after the subsurface object it is made I over. You use an
