When you are in the Thermal Zone tab in OS and you edit the schedules, you are deleting or changing the schedule on a thermostat, not editing or changing the thermostat itself. To do what you are talking about you need to make a new thermostat in SketchUp, and then apply it to the zones you want in SketchUp as well.
First you need to make heating and cooling schedules that you want in OS. image description
Next in the inspector tool in OS add a thermostat and assign the schedules you made. image description
Finally assign this thermostat to the desired zones in Sketchup's inspector tool.image description
