Your model is probably requesting output variables in excess of what you need. Particularly, output variables of the 'Surface', 'Zone' and 'System Node' variety, with key values set to 'All' (i.e. "*") for large models will result in large amounts of data in the output files.
Your model is probably requesting output variables in excess of what you need. Particularly, output variables of the 'Surface', 'Zone' and 'System Node' variety, with key values set to 'All' (i.e. (e.g. "*") for large models will result in large amounts of data in the output files.files.
