In the EnergyPlusVn-m-0\ExamplesFiles folder, there are two files that index all of the example files. ExampleFiles.html and ExampleFiles-ObjectsLink.html. The objectslink file lists every EnergyPlus object type and the first few example files which use it. ZoneControl:Thermostat:ThermalComfort points to example file FurnaceWithDXSystemComfortControl.idf.
I cannot say that I have actually tried it, but this thermostat type should work with ZoneHVAC:IdealLoadsAirSystem.
In the EnergyPlusVn-m-0\ExamplesFiles EnergyPlusVn-0-0\ExamplesFiles folder, there are two files that index all of the example files. ExampleFiles.html and ExampleFiles-ObjectsLink.html. The objectslink file lists every EnergyPlus object type and the first few example files which use it. ZoneControl:Thermostat:ThermalComfort points to example file FurnaceWithDXSystemComfortControl.idf.
