Are you intending to only use EnergyPlus for the simulations, or were you hoping to use Radiance in the workflow as well? If the former, I think my colleagues have some leads for you. It may be that you simply use an EnergyPlus measure to add the schedule to the window construction; if the latter, the answer is 'no'.
