I checked your model. There was no thermal zone, construction set, and schedule set assigned to two of the spaces you had. After applying some values from your library (I picked them randomly since I don't have enough info about your model's properties), I increased the thermal conductivity of your "Netzero wall", which is the main wall assembly in your model and the total energy consumption bumped up accordingly. So, you should double check all the spaces you have and make sure correct properties are assigned to them. The rest of the model seems to be correct.
