@Saif that looks like an error in the measure specific to CoilCoolingWaterToAirHeatPumpEquationFit objects, we called invalid methods for this object type. I'll file an issue for this. It was failing on the last line in code below.
when OpenStudio::Model::CoilCoolingWaterToAirHeatPumpEquationFit.iddObjectType
coil = e.to_CoilCoolingWaterToAirHeatPumpEquationFit.get
coil.isRatedTotalCoolingCapacityAutosized && coil.isRatedSensibleHeatRatioAutosized && coil.isRatedAirFlowRateAutosized ? 'Yes' : 'No'
If you feel comfortable changing line 114 in the measure.rb file you can try changing it to this.
coil.isGrossRatedTotalCoolingCapacityAtSelectedNominalSpeedLevelAutosized && coil.isRatedAirFlowRateAtSelectedNominalSpeedLevelAutosized && coil.isRatedWaterFlowRateAtSelectedNominalSpeedLevelAutosized ? 'Yes' : 'No'
@Saif that looks like an error in the measure specific to CoilCoolingWaterToAirHeatPumpEquationFit objects, we called invalid methods for this object type. I'll file an issue for this. It was failing on the this last line in code below.line
@Saif that looks like an error in the measure specific to CoilCoolingWaterToAirHeatPumpEquationFit objects, we called invalid methods for this object type. objects. I'll file an issue for this. It was failing on this last line
