@antonszilasi that looks good, but if you are not filtering by spaces at all, then you can just loop through sub_surfaces directly, and then just set the constructions within the elsif statements.
model.getSubSurfaces.each do |sub_surface|
# only alter exterior windows.
next if sub_surface.subSurfaceType != 'FixedWindow'
next if sub_surface.outsideBoundaryCondition != 'Outdoors'
# store absoluteAzimuth
absoluteAzimuth = OpenStudio.convert(sub_surface.azimuth, 'rad', 'deg').get + sub_surface.space.get.directionofRelativeNorth + model.getBuilding.northAxis
absoluteAzimuth -= 360.0 until absoluteAzimuth < 360.0
# check orientation and assign construction
if (options['northEast'] <= absoluteAzimuth) && (absoluteAzimuth < options['southEast']) # East exterior walls
sub_surface.setConstruction(WindowTypeEast)
elsif (options['southEast'] <= absoluteAzimuth) && (absoluteAzimuth < options['southWest']) # South exterior walls
sub_surface.setConstruction(WindowTypeSouth)
elsif (options['southWest'] <= absoluteAzimuth) && (absoluteAzimuth < options['northWest']) # West exterior walls
sub_surface.setConstruction(WindowTypeWest)
else # North exterior walls
sub_surface.setConstruction(WindowTypeNorth)
end
end
next if sub_surface.subSurfaceType sub_surface.surfaceType != 'FixedWindow'
'Wall'
end
end
