None of these should sum to 8760. "Unmet Clg" is all unmet cooling hours (occupied and unoccupied, not just unoccupied). "Unmet Clg - Occ" just includes hours in which there are occupants (as you likely inferred). So, it is reasonable for these to sum to a value greater than 8760; however, neither of these values should exceed 8760, individually, and "Unmet Clg - Occ" should always be less than or equal to "Unmet Clg." Does this make sense?
None of these should sum to 8760. "Unmet Clg" is all unmet cooling hours (occupied and unoccupied, unoccupied - not just unoccupied). "Unmet Clg - Occ" just includes hours in which there are occupants (as you likely inferred). So, it is reasonable for these to sum to a value greater than 8760; however, neither of these values should exceed 8760, individually, 8760 and "Unmet Clg - Occ" should always be less than or equal to "Unmet Clg." Does this make sense?
