Due to the nature of the SketchUp plug-in this will happen. Are you working with the legacy OpenStudio plug-in that works directly on IDF files or the SketchUp plug-in in the new OpenStudio application suite (works on OSM files and comes with OpenStudio Application, PAT, and ResultsViewer)? If you are working with the legacy plug-in, simply don't open your file in the plug-in after adding window reveals. If you are working with the new OpenStudio plug-in, we have added a feature to the Window Frame and Divider object that will be available in the 1.7.0 installer. We have added a new field to that object so you can draw your windows on their base surfaces and they will be offset when translated from OSM to IDF.
