Thank you for posting the EnergyPlus GitHub issue, it sounds like you have found a bug. I would suggest that you temporarily comment out the DaylightingDevice:Shelf object and the objects referenced in the inside shelf name and outside shelf name. Rerun the file and that should tell you if the rest of the geometry is ok.
