From the report that you shared, the time of day for the facility peak is 5:15 am on Sep 21. I would guess that at that time of day there is no solar load. Although I also see that the estimate on the component loads is not a very good one. The line "Difference Between Peak and Estimated Sensible Load " is very large so I would not trust the component loads. Please review the input output reference and the engineering reference.
From the report that you shared, the time of day for the facility peak is 5:15 am on Sep 21. I would guess that at that time of day there is no solar load. Although I also see that the estimate on the component loads is not a very good one. The line "Difference Between Peak and Estimated Sensible Load " is very large so I would not trust the component loads. Please review the input output reference and the engineering reference.load.
