Check the line-by-line results in the edd output file to see if the program is working as expected. The sensor object looks wrong, because the key name for Site Outdoor Air Drybulb Temperature should be "Environment", not a zone name. The program above looks similar to example file EMSAirflowNetworkOpeningControlByHumidity.idf.
Another option is to use AvailabilityManager:HybridVentilation which can be used to control natural ventilation with AirflowNetWork or ZoneVentilation and it has limits for max/min outdoor dry-bulb and wet-bulb temperature.
