it would be a lot of work to figure out how to run it without docker. Plus going forward you'd have to manage all the new changes yourself. So if you want to stick with 2012, looks like your best bet is to run an ubuntu VM and then standup the docker images in that. The biggest performance hit will come from disk IO between the VM and the base server, so try and optimize that if you can.
