If you have already installed SketchUp 2015, the OpenStudio 1.6.2 installer should install the necessary plug-in files. It is important to install the 64 bit version of OpenStudio to work with the 64 bit version of SketchUp (or 32 bit with 32 bit) and also to install SketchUp before you install OpenStudio. If you are still having problems see these posts:
  • https://unmethours.com/question/2677/sketchup-looking-for-os150-when-os16-is-installed/
  • https://unmethours.com/question/1209/install-openstudio-plugin-for-sketchup-2014-for-windows/
  • https://unmethours.com/question/1047/sketchup-2015-and-open-studio-15/
