The difference between the simple opening and detailed opening is the complexity of the inputs required for the model. The Input Output Reference describes these differences. For both these objects it is possible to have both positive and negative flows depending on the neutral height location on the surface. See the documentation for more information. And as described, the detailed reporting frequency is best for diagnosing results when questions arise since longer reporting frequencies will average the results.
