The OpenStudio API for ShadowCalculation doesn't currently expose the calculation method. Instead of hand editing the IDF, you could create an EnergyPlus measure to change this as a cleaner solution than hand editing. This would also allow you to disable the measure for quick testing, and then enable it when you need it.
