OK, so how can we get both EnergyPlus results in IP units, AND OpenStudio results in IP units? If we run the "Energyplus output to IP" measure, the OS results will fail. If we omit this measure and run only the OpenStudio Results measure, then we get no IP Energyplus results, just the SI version. How to get both?
This is even more puzzling because my coworker IS getting both. He's running both of these measures listed above, and it's not failing, and it's reporting both E+ and OS results in IP format. How is this possible? Something about his computing environment, because he runs my failing files and they work for him. I run his working (=reporting in dual IP) files, and they fail for me (= OS results fails on E+ IP units). We're both running OS v2.6.1 on Windows 10.
Update 1: So the answer is: my coworker is running a personal-library OLD VERSION of the OpenStudio Results measure, which doesn't crash upon receiving E+ results that have been converted to IP. His version is 10/24/2016. The newer version that is current on the BCL will fail and crash if it receives E+ results in IP.
These old and new measures have the same name, and they are indistinguishable to the user, unless you can find and read the actual Ruby text. To make this more difficult, one is saved in C:...User/Name/BCL and the other in C:...User/Name/Openstudio/Measures, yet they both appear as the same thing in the OS interface. One has the "BCL" brand and the other has the "My" brand, respectively. It's only by the grace of goddess that my coworker's measure was downloaded and saved offline, so it wasn't erased/synced to the current BCL version that is broken.
Update 1: P.S. So the answer is: my coworker is running a personal-library OLD VERSION of the OpenStudio Results measure, which doesn't crash upon receiving E+ results that have been converted to IP. His version is 10/24/2016. The newer version that is current on the BCL will fail and crash if it receives E+ results in IP.
These old and new measures have the same name, and they are indistinguishable to the user, unless you can find and read the actual Ruby text. To make this more difficult, one is saved in C:...User/Name/BCL and the other in C:...User/Name/Openstudio/Measures, yet they both appear as the same thing in the OS interface. One has the "BCL" brand and the other has the "My" brand, respectively. It's only by the grace of goddess that my coworker's measure was downloaded and saved offline, so it wasn't erased/synced to the current version that is broken.
