Fellow Mac user here. This is normal, I've gotten the same message when installing multiple OpenStudio versions in the past. For everyone else, the message @EnergyPlusEmail is referring to is below.
To get around this, you'll need to go into your machine's System Preferences / Security & Privacy / General section. You should see a window similar to the image below.
Click on the Open Anyway button on the right, and the OpenStudio installer should be able to run.
