If your OpenStudio simulation was successful, then it has already generated an EnergyPlus input file. In the folder where your .osm file is saved, there should be a folder with the same name as your .osm (My Model folder for My Model.osm, e.g.). In that folder, the run folder will contain the .idf, which is the input file for EnergyPlus. You should be able to run this directly in EP-Launch.
To resolve your issue with the translated EnergyPlus file, in the same folder as the .idf that caused your error messages there should be a .audit file with the same name. Search for "error", "fatal", "fail", etc. in this audit file to see if there are any clues as to what is wrong with the translated EnergyPlus file.
