This might work:
Make the clerestories with solid walls and a solid roof first on the main surface. Create windows in the walls and roof of the clerestories leaving a small perimeter frame on each surface. Using the cross section tool if necessary, delete the subsurface created by each of the clerestory objects on the main surface.
