your best bet is to move the window and flush it with the wall surface. Select the window then use the move tool to grab the window and hover on the wall until the tool shows "on Face". this way you will have it flushed with the wall and you can draw the rectangle on the window.
Also I am not sure if you watched these tutorials:
your best bet is to move the window windows and flush it with the wall surface. Select the window then use the move tool to grab the window and hover on the wall until the tool shows "on Face". this way you will have it flushed with the wall and you can draw the rectangle on the window.Face".
Also I am not sure if you watched these tutorials:tutorials
your best bet is to move the windows and flush it with the wall surface. Select the window then use the move tool to grab the window and hover on the wall until the tool shows "on Face".
Modeling From Imported Plans and Elevations - part 1
