That sounds like an issue with the lights schedule, whereas your attempts to fix that (changes to SU model, Radiance measure settings) won't fix that. Does the model run with EnergyPlus alone, i.e. not using the Radiance measure in the workflow at all? What does "had a look at my electric lighting schedule" mean? Could you maybe post the osm somewhere so we could take a look at it?
