We keep a copy of our NRCan OpenStudio Server AMI on a Canadian Amazon Server.
Here is a script that we use internally that will launch our version of OS Server on Canadian soil.. It is mostly the same as the standard OS Server that NREL produces. It currently supports server 2.6.0...We will create an image for 2.7.0 in a few weeks since it just came out.
Once this is run and the cluster finished initializing, you can point PAT to the IP address of the server as @David Goldwasser mentioned.
https://github.com/canmet-energy/start_aws_server
Please ensure that you manage / turn off the instances in the AWS console when you are done to avoid charges.
Here is a unsupported script that we use internally that will launch our version of OS Server on Canadian soil.. It is mostly the same as the standard OS Server that NREL produces. It currently supports server 2.6.0...We will create an image for 2.7.0 in a few weeks since it just came out.
Please ensure that you manage / turn off the instances in the AWS console when you are done to avoid charges.charges.
