Add an Output:Variable for each coil:
Output:Variable,
Example Coil Name 1, !- Key Value
Heating Coil Heating Rate, !- Variable Name
Timestep; !- Reporting Frequency
Output:Variable,
Example Coil Name 2, !- Key Value
Or use the variable name 'Heating Coil Heating Energy' instead. Valid reporting frequencies are 'Detailed', 'Timestep', 'Hourly', 'Monthly', 'Annual', or 'RunPeriod'.
