The ZoneThermalChimney object does not interact with the airflow network. The documentation for the airflow network is pretty clear that several of the simpler airflow objects don't work with when the airflow network is simulating. I haven't confirmed this, but I suspect that when you have an airflow network operating, the ZoneThermalChimney falls under the same constraint.
