For a simple single-speed cooling-only split DX system, ZoneHVAC:WindowAirConditioner
should work fine. Just be sure to set the nominal performance to be appropriate for the system type. The split system is likely to have higher supply fan pressure and different cooling COP. Other options that would also work are ZoneHVAC:PackagedTerminalAirConditioner
(PTAC) and AirloopHVAC:UnitarySystem
As a side note, "no error displayed" does not necessarily mean that the simulation is working as desired. At a minimum, always check the hours thermostat setpoint not met to be sure that the zone was conditioned properly.
