You can start by reading the Getting Started document in the documentation folder (e.g., C:\EnergyPlusV8-9-0\Documentation). In the root folder (e.g., C:\EnergyPlusV8-9-0) open EP-Launch and under Input File click the Browse button. Goto the example files folder (e.g., C:\EnergyPlusV8-9-0\ExampleFiles) and look for WindACAuto.idf or WindACRHControl.idf and select either file. Then click the Simulate button. After the simulation executes open the Tables and Variables files to review the results.
