The set point manager of choice does not influence the size of the cooling (or heating) coil. I would check the information in the Sizing:Zone (used to size zone air flow) and Sizing:System (used to size capacity) objects. If reheat is not active in a zone I would check the zone temperature with respect to the zone thermostat temperature to see if reheat is actually needed. If you need help reporting this information then simply ask for that additional help.
