It definitely matters, but by how much is the question. If you are interested in design day peak load calculations, which is used for equipment sizing, it will matter. Mechanical engineers size based on specific sets of design weather data, often obtained from ASHRAE, and based on dry-bulb and mean-coincident wetbulb temperatures which correspond to 99.6% annual cumulative frequency for heating, and 0.4%annual cumulative frequency for cooling. This is the information that is in the DDY (design day) file.
You can find the ASHRAE design day data here: http://ashrae-meteo.info/
If you are just interested in energy, it can still affect results. Peak design day conditions do not necessarily correlate to the peak conditions found in an annual weather file. They can be higher or lower. This will affect the equipment size, and in turn affects the energy use of that equipment in your simulation.
You can find the ASHRAE design day data this information summarized here: http://ashrae-meteo.info/
