The only way to get a separate energy consumption for each zone system is to create separate meters in Apache, and then assign them to the zone components. You could also select each zone component(make sure component results are enabled in output options) in VistaPro to view the component results. It would be layer by layer though. If you are looking for the peak load and the various contributions at each zone, then that can be found in the system sizing report.
