Once you have one of the the calibration reporting measures described in this post go to the Outputs Tab in PAT. Once you select the calibration measure you should see cvrmse and nmbe outputs each for both gas an electricity. Set the objective column to true for these, and weight them if desired. After this you are ready to go to the run tab to run the analysis.
