The server will have access to the weather file to run, but it won't automatically update the design days the climate zones, and water main temperatures. You should add the ChangeBuildingLocation measure to your workflow, and manually copy the .ddy and .stat files into the weather directory next to the .epw. The measure argument for the weather file should just need the file name and not any path.
