From a short glimpse at your model I believe that your Cooling and Heating Schedules are not working as you meant it to work. If you look inside those schedules you will find out that they are having only the default values through out the year. The reasons for that is that you forgot to select the days to apply the priority 1 and 2 day schedules. One other issue is that both priority 1 and 2 day schedules are valid all through the year while I think you wanted them to be summer or winter only.
you set the Heating temp of all of your zones to 10.6 Celsius and Cooling to 30.1 Celsius. With that most of the time the temperature of your zones will run free and you can't control the humidity.
I believe that after you will correct that you will see better results
From a short glimpse at your model I believe that your Cooling and Heating Schedules are not working as you meant it to work. If you look inside those schedules you will find out that they are having only the default values through out the year. The reasons for that is that you forgot to select the days to apply the priority 1 and 2 day schedules. One other issue is that both priority 1 and 2 day schedules are valid all through the year while I think you wanted them to be summer or winter only.schedules.
