The documentation you linked to is for the older version of PAT, the 2.x PAT documentation is here. It appears that the region in the GUI is locked down. You can setup your own server, I can provide more details on that if you are interested, and then on the Run Tab of PAT you can point it to the existing running server.
Just out of interest, can you provide more detail on why you want to select a specific region?
