The object you are looking for is ZoneHVAC:WindowAirConditioner.
You can look at 'HVACStandAloneERV_Economizer.idf' example file which you can find under the exampleFiles directory in your E+ installation directory.
Generally speaking you might want to use the 'ExampleFiles-ObjectsLink.html' to find examples with Objects of interest. Also you can use the ExampleFiles.html to find what is inside the example files. Both html files are also located under the above mentioned directory.
