No, OpenStudio 2.6.0, 2.7.0, and 2.8.0 are not compatible with SketchUp 2018. I've experienced the error below a couple times before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently. See the OpenStudio Version Compatibility Matrix and the SketchUp RuntimeError: bad_weak_ptr issue.
No, OpenStudio 2.6.0, 2.7.0, and 2.8.0 are not compatible compatible with SketchUp 2018. I've experienced the 2018, which has an error below when opening a couple times SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently. See the OpenStudio Version Compatibility Matrix and the SketchUp RuntimeError: bad_weak_ptr issue..
No, OpenStudio 2.6.0, 2.7.0, and 2.8.0 are not compatible with SketchUp 2018, which has an error when opening a SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently. See the OpenStudio Version Compatibility Matrix.intermittently.
No, OpenStudio 2.6.0, 2.7.0, and 2.8.0 are 2.6.0 is not compatible with SketchUp 2018, which has an error when opening a SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently.
No, OpenStudio 2.6.0 is not compatible with SketchUp 2018, which has an error when opening a SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently.2018.
