Using the measures tab in the OpenStudio application or in PAT make a copy of the measure from the BCL. The copy should be in your "My Measures" directory. The "resources" directly within the measure folder contains a series of IDF files. You can alter existing get or add new files to expose more options for the measure. The choice list in the measure is dynamically generated from these files.
