If you use 1000 kWhs in a month and your utility bill is 100 USD, then your average electricity rate is 100/1000 = 10 cents/kWh. If your bill contains a monthly fixed charge of 20 USD that is independent of how much electricity you consumed, then the marginal electricity rate is (100 - 20)/1000 = 8 cents/kWh.
If you simply used the average electricity rate of 10 cents/kWh in a tool like BEopt, you'd get incorrect results. For example, for a month with 2000 kWhs consumption, it’d incorrectly calculate a utility bill of 2000 * 0.10 = 200 USD using the average rate when it is instead 20 + 2000 * 0.08 = 180 USD. In other words, it’s important to calculate utility bills using fixed charges and marginal electricity rates, not average electricity rates.
If you simply used the average electricity rate of 10 cents/kWh in a tool like BEopt, you'd get incorrect results. For example, for a month with 2000 kWhs consumption, it’d you’d incorrectly calculate a utility bill of 2000 * 0.10 = 200 USD using the average rate when it is instead 20 + 2000 * 0.08 = 180 USD. In other words, it’s important to calculate utility bills using fixed charges and marginal electricity rates, not average electricity rates.rates.
