The upper image is showing the average value that a variable takes over the month, not the sum. Those variables are reporting at the timestep or hourly level, so you're seeing the average timestep or hourly value for the month. If you want to see the totals by month, get the sum from the 'Statistics' tab and check the 'Show Monthly Values' checkbox.
