If you are referring to simple or detailed surface geometry OpenStudio uses the FenstrationSurface:Detailed approach.
However you may be referring the the performance characteristics of the glazing, in which case OpenStudio has access to both WindowMaterial:SimpleGlazingSystem and the more detailed WindowMaterial:Glazing
