E+ 8.9.0 recently added a new field to the ZoneHVAC:EquipmentList
, that is Load Distribution Scheme.
This field isn't exposed in OpenStudio (neither the OS App nor the SDK), so it will just default to SequentialLoad
, which happens to be exactly what you need it to be.
You need to properly define the equipment priorities though: you want the radiant to be 1 and the VRF to be 2.
In the OS Application, the priority is defined by the order in which you added the equipment. In the SDK (ie in a script or a measure), it's easy to change the priority for a given equipment.
