To achieve code folding, I've found a workaround that consists in using the User Language and a macro to include opening and closing statements. It will allow folding entire classes or just objects (retaining only the object type and its Name, not the other attributes: see second image below)
In the User Defined language, I've set in "Folding in comment style". Open: "#[" "#{". Close: "]#" "}#" Brackets are for objects and curly braces for classes.
I created a macro to include those opening and closing statements in the IDF file. It's using the comments that are auto-generated when saving via the IDF editor, and I'm assuming it's in "sortedorder" considering I'm also folding the classes. The macro is basically performing a few Find and replace based on regular expression. You will need to modify the "shortcuts.xml" file located in "%appdata%\Notepad++/" and add the macro. I don't see an option to post and format code here, so I created a pastebin located here. Make sure you save shortcuts.xml while Notepad++ is closed.
Then you can reopen notepad++, and under "Macro" run the "Add brackets to Eplus classes" one. Then try folding level 2 with ALT+2, then the rest with ALT+1.
I'll welcome any feedback/bug report, especially considering I only tested it on a couple of files, so there are some exception I might not be handling properly.
UPDATE
Navigation with anchors to classes:
For this, we'll use what is called "Function List" (thanks to @JasonGlazer for pointing out it existed)
Use the shortcut [Windows] + R to bring up the run prompt, and type in : %appdata%/notepad++ Windows Explorer will open to the folder in which you'll find functionlist.xml. This is the file you need to modify, and notepad++ must be closed when you save it. So either modify with another text editor, or modify in another location then copy paste. I suggest the latter. And make a copy of your original functionlist.xml just in case, never too safe.
In the section, add an association (see link to pastebin below). In the first association, with "userDefinedLangName", replace "EnergyPlus-JM" with whatever name you used for your user defined language. (Or delete it) The second association with "ext" associates any file with the extension .idf.
In the "parsers" section, add a new parser with the id "energyplus_class" (see pastebin)
After replacing/saving (with notepad++ closed), reopen notepad++. To see the "navigation pane", you need to activate the Function List pane by clicking on "View" in the navigation menu (top of windows) then "Function List", and you should see something like the following. Notice the pane on the right.
Here is the pastebin
Update: Github repo
Go to my Github repository for the latest files and installation instructions.
UPDATE
Update: Github repo
, since I couldn't format code properly...To achieve code folding, I've found a workaround that consists in using the User Language and a macro to include opening and closing statements. It will allow folding entire classes or just objects (retaining only the object type and its Name, not the other attributes: see second image below)
UPDATE
List", and you should see something like the following. Notice the pane on the right.List".
Here is the pastebin, since I couldn't format code properly...
UPDATE
below).below) In thefirst association, with "userDefinedLangName",first, with "userDefinedLangName" replace"EnergyPlus-JM""EnergyPlus-JM with whatever name you used for your user defined language. (Or delete it) Thesecond associationsection, with "ext" associates any file with the extension .idf.In the "parsers" section, add a new parser with the id "energyplus_class" (see pastebin)
After replacing/saving (with notepad++ closed), reopen notepad++. To see the "navigation pane", you need to activate the Function List pane by clicking on "View" in the navigation menu (top of windows) then "Function List".
UPDATE
For this, we'll use what is called "Function List" (thanks to @JasonGlazer @Jason Glazer for pointing out it existed)
In the section, add an association (see link to pastebin below) In the first, with "userDefinedLangName" replace "EnergyPlus-JM with whatever name you used for your user defined language. (Or delete it) The section, with "ext" associates any file with the extension .idf.
UPDATE
For this, we'll use what is called "Function List" (thanks to @Jason Glazer for pointing out it existed)List".
For this, we'll use what is called "Function List".
association (see link to pastebin below)associationIn the first, with "userDefinedLangName" replace "EnergyPlus-JM with whatever
nameyouused fornamed your user definedlanguage.language as. (Or delete it) The section, with "ext" associates any file with the extension .idf.In the "parsers" section, add a new parser with the id
"energyplus_class" (see pastebin)"energyplus_class".
4. After replacing/saving (with notepad++ closed), reopen notepad++. To see the "navigation pane", you need to activate the Function List pane by clicking on "View" in the navigation menu (top of windows) then "Function List".
In the first, with "userDefinedLangName" replace "EnergyPlus-JM with whatever you named your user defined language as. (Or delete it) The section, with "ext" associates any file with the extension .idf.
In the "parsers" section, add a new parser with the id "energyplus_class".
.Make sure you save shortcuts.xml while Notepad++ is closed.Then you can reopen notepad++, and under "Macro" run the "Add brackets to Eplus classes" one. Then try folding level 2 with ALT+2, then the rest with ALT+1.
