Other than using the EnergyPlus Weather Converter program with a def file you should build (which shouldn't be too hard to do) You can try the CCWeatherGen which is aimed at Climate Change Weather File Generating for the UK. From taking a brief look at the manual it seems that you can generate also ‘unmorphed’ data.
